Excel Sensitivity Label - how can I improve my solution?
TomaszSadlon
Hey guys,
This is gonna be a pretty long post 😉
So lately my organization introduced mandatory sensitivity labels in Office 365 documents. We're unable to save any newly created document unless we set the label during saving (if no label is already present, of course). This is not a functionality supported in Excel VBO, so I started investigating the subject to come up with a way to implement that.
There is, of course, the Microsoft Information Protection VBO, but there are some downsides to it:
  • As far as I can see, it works only on already saved documents (so it won't work on a freshly created instance of Excel, since we're unable to save it first)
  • It needs to be specifically implemented in all of the processes (which we have hundreds of, and would take a lot of time and work)
What I already have:
For now, this is what I came up with as a quick workaround:
  1. I've edited the Excel VBO, so that right before attempting to save the document it launches the following code stage. Basically it just inserts a VBA module with a macro, invokes the macro and cleans up after itself.
    Dim xlApp as Object = GetInstance(handle)
    Dim xlwb as Object = GetWorkbook(handle,workbookname)
    xlApp.DisplayAlerts = False
    if xlwb.SensitivityLabel.getlabel().LabelId = "" Then
    		'add vba module
    	Dim vbamodule = xlwb.VBProject.VBComponents.Add(1)
    		'inject macro into the module we created
    	vbamodule.CodeModule.AddFromString(macro)
    		'run macro to change the sensitivity label
    	xlApp.Run(macro_name)
    		'erase our module
    	xlApp.VBE.ActiveVBProject.VBComponents.Remove(vbamodule)
    End If
    xlApp.DisplayAlerts = True
  2. The macro, passed in the macro variable, looks like this (Label properties are xxx'd out for sec purposes, of course 😉 ):
    Sub setLabel()
    On Error GoTo saveError
        Dim label As SensitivityLabel
        Dim labelInfo As Office.labelInfo
        If (Application.ThisWorkbook.SensitivityLabel.GetLabel() = "") Then
            Set label = Application.ThisWorkbook.SensitivityLabel
            Set labelInfo = label.CreateLabelInfo()
            With labelInfo
                .AssignmentMethod = MsoAssignmentMethod.PRIVILEGED
                .LabelId = "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxx"
                .LabelName = "xxxxxxx"
                .SiteId = "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxx"
            End With
        label.setLabel labelInfo, labelInfo
        End If
    Exit Sub
    saveError:
        Dim fs, f, currentdte
        Set fs = CreateObject("Scripting.FileSystemObject")
        Set f = fs.OpenTextFile("C:\temp\sensitivityLabel.log", 2, True)
        f.WriteLine CStr(Now) + " - " + Err.Description
        f.Close
    End Sub
    So basically we have the ability to set the label using a macro before saving the document and all is well in the world :)... *huge "BUT" incoming*
This solution works for the most part. Not sure why, but in certain processes, under some circumstances, which I'm unable to pinpoint, this solution gives out an error:
Could not execute code stage because exception thrown by code stage: Can't perform operation since the project is protected.
Plus, it just seems... Hacky? Can't really say, that this is a stable, production-ready solution. At least not to my standards as a dev 😉 I feel we can do better here.
What I'm after:
I'm attempting to implement the whole thing as a code stage with no macro-injecting-hope-it-works-hoop-jumping.
The main issue here is this line of the macro code:
My research shows, that it's connected to the Microsoft Office 16.0 Object Library, thus there's no problem to call it via VBA. Soo, I should be able to reference the MSO.dll in the Excel VBO's Initialize page and use it in my code, right? Well, no. The moment I add mso.dll to the references, this happens:23765.png
So far I also had no success in using the Microsoft.InformationProtection.dll to create a valid AssignmentMethod object.
So, my questions are:
1) How do you guys handle the Sensitivity Label in your work envs?
2) Do you have any idea how can I improve my solution to be more bullet-proof (in case of my workaround solution) or work at all? (in case of my "What I'm after" solution)?
3) Does BluePrism, as the provider of the Excel VBO, has any plans to actually address this problem (which is not exactly new, according to my findings)?
SOLUTION:
In case anyone's looking for a solution, here's the code stage (no additional references required):
Dim sensLabel As Object = xlwb.SensitivityLabel
Dim labelInfo As Object = sensLabel.CreateLabelInfo()
If (sensLabel.GetLabel().LabelId() = "") Then
        With labelInfo
            .AssignmentMethod = 1
            .LabelId = "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx"
            .LabelName = "xxxxxx"
            .SiteId = "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx"
        End With
        sensLabel.setLabel(labelInfo, labelInfo)
End If
This, of course, sets a given label just in case of lack of a set label in the workbook. You can modify/delete the If statement to alter this behavior 🙂
Tomasz Sadlon
RPA Dev
Nordea AB
Europe/Warsaw
The GetLabel call results in a LabelInfo (COM)Object
In VBA this is an Object that will auto-resolve to a string(in fact the LabelId property of the LabelInfo Object)
Here you either try to explicitly call .ToString() on the end - if that does give the same outcome as VBA
If xlwb.SensitivityLabel.GetLabel().ToString() = ""
OR better yet, go for the known property that you want to test(which is LabelId I assume):
If xlwb.SensitivityLabel.GetLabel().LabelId = "" Then
Anton Hosang
Director
Omega RPA Ltd
12 REPLIES 12
PvD_SE
Level 12
Hi T,
As a workaround, would it be feasible to not create a new document but instead open an existing template with the sensitivity label already set, populate that and then do a 'Save as'? The template can either be totally blank or contain template text, as long as the sensitivity label has already been assigned in it.
Happy coding!
Paul
Sweden
(By all means, do not mark this as the 'Best answer'! )
Happy coding!
Paul, Sweden
Anton__Hosang
Try getting rid of any reference to the Office dll. VB has the  implicit typing/infer option set in BP, so try declare the Sensitivity & labelInfo variables as Object and hopefully their COM implementations stand up (some members can be mangled such as some sendermail stuff in Outlook, and the removeDuplicates method in Excel).
Put things back as they were, and can't you just use the value of the enum?
.AssignmentMethod = 1       'MsoAssignmentMethod.PRIVILEGED = 1
On another point wouldn't it be better to return error strings after catch and have the exception logging for all your VBO calls in a separate page?
I doubt BP will address this as their VBO is meant as a starter codeset - and very much needs your own considered enhancement.
Anton Hosang
Director
Omega RPA Ltd
Hi Tom,
There is an asset for M365 - Excel in DX but unfortunately it doesn't have assign sensitivity label action. You need to create the custom action to assign the sensitivity label. Refer the below Graph API documentation to create the custom action.
DX Asset : Microsoft 365 - Excel - 1.5.0
Graph API : Graph API - assignSensitivityLabel
Athiban Mahamathi - https://www.linkedin.com/in/athiban-mahamathi-544a008b/
Technical Consultant,
SimplifyNext PTE LTD,
Singapore
I would go with Paul's suggestion to use a template.
  • Create an Excel file manually with all the structure, formatting, formulas, sensitivity etc you need.
  • Import it into the initial value of a BP binary data item.
  • Design your process to write the binary data item out to create a new file.
  • Open the file, add data or whatever you need to do.
  • Save and close.
John Carter
@Athiban Mahamathi Mathialagan,
Glad you pointed this out. For the longest time Microsoft only supported this under the beta release of the Graph API. Now that it shows up as part of the officially supported 1.0 release, we will look to add it to the connectors we have on the DX. 😉
Hi Tomaz,
I normally use the solution proposed by Paul and I haven't had any problems with it, it works perfectly.
The only point of attention is to keep the file protected in the original directory and instruct the team to copy it and not write to it directly.
Leonardo Soares
América/Brazil
@TomaszSadlon I quickly knocked up an action to use this property as it hadn't been in use for me before.
Works for me as simple as said above.
Take out any referencing in the Initialize page re office dlls and declare as Objects. Then you simply need to use the Int value:
In general, when trying to convert VBA code to VB.NET, just use the Integer value of any Enums (find by hovering over a started routine in VBA editor, or look it up on the docs page)
Anton Hosang
Director
Omega RPA Ltd
Hey Anton,
I tried doing this before and failed... Maybe you could point out my mistake 🙂
This is the code stage:
    If (xlwb.SensitivityLabel.GetLabel() = "") Then
        sensLabel = xlwb.SensitivityLabel
        labelInfo = sensLabel.CreateLabelInfo()
        With labelInfo
            .LabelName = "xxxxx"
        End With
    End If
Here are the references:
And this is the error I'm getting:
Internal : Could not execute code stage because exception thrown by code stage: Overload resolution failed because no Public '=' can be called with these arguments:
    'Public Shared Operator =(a As String, b As String) As Boolean':
        Argument matching parameter 'a' cannot convert from '__ComObject' to 'String'.
Any idea what am I missing?
Tomasz Sadlon
RPA Dev
Nordea AB
Europe/Warsaw
Anton Hosang
Director
Omega RPA Ltd
