Excel Sensitivity Label - how can I improve my solution?
TomaszSadlon
Hey guys,
This is gonna be a pretty long post 😉
So lately my organization introduced mandatory sensitivity labels in Office 365 documents. We're unable to save any newly created document unless we set the label during saving (if no label is already present, of course). This is not a functionality supported in Excel VBO, so I started investigating the subject to come up with a way to implement that.
There is, of course, the Microsoft Information Protection VBO, but there are some downsides to it:
  • As far as I can see, it works only on already saved documents (so it won't work on a freshly created instance of Excel, since we're unable to save it first)
  • It needs to be specifically implemented in all of the processes (which we have hundreds of, and would take a lot of time and work)
What I already have:
For now, this is what I came up with as a quick workaround:
  1. I've edited the Excel VBO, so that right before attempting to save the document it launches the following code stage. Basically it just inserts a VBA module with a macro, invokes the macro and cleans up after itself.
    Dim xlApp as Object = GetInstance(handle)
    Dim xlwb as Object = GetWorkbook(handle,workbookname)
    xlApp.DisplayAlerts = False
    if xlwb.SensitivityLabel.getlabel().LabelId = "" Then
    		'add vba module
    	Dim vbamodule = xlwb.VBProject.VBComponents.Add(1)
    		'inject macro into the module we created
    	vbamodule.CodeModule.AddFromString(macro)
    		'run macro to change the sensitivity label
    	xlApp.Run(macro_name)
    		'erase our module
    	xlApp.VBE.ActiveVBProject.VBComponents.Remove(vbamodule)
    End If
    xlApp.DisplayAlerts = True
  2. The macro, passed in the macro variable, looks like this (Label properties are xxx'd out for sec purposes, of course 😉 ):
    Sub setLabel()
    On Error GoTo saveError
        Dim label As SensitivityLabel
        Dim labelInfo As Office.labelInfo
        If (Application.ThisWorkbook.SensitivityLabel.GetLabel() = "") Then
            Set label = Application.ThisWorkbook.SensitivityLabel
            Set labelInfo = label.CreateLabelInfo()
            With labelInfo
                .AssignmentMethod = MsoAssignmentMethod.PRIVILEGED
                .LabelId = "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxx"
                .LabelName = "xxxxxxx"
                .SiteId = "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxx"
            End With
        label.setLabel labelInfo, labelInfo
        End If
    Exit Sub
    saveError:
        Dim fs, f, currentdte
        Set fs = CreateObject("Scripting.FileSystemObject")
        Set f = fs.OpenTextFile("C:\temp\sensitivityLabel.log", 2, True)
        f.WriteLine CStr(Now) + " - " + Err.Description
        f.Close
    End Sub
    So basically we have the ability to set the label using a macro before saving the document and all is well in the world :)... *huge "BUT" incoming*
This solution works for the most part. Not sure why, but in certain processes, under some circumstances, which I'm unable to pinpoint, this solution gives out an error:
Could not execute code stage because exception thrown by code stage: Can't perform operation since the project is protected.
Plus, it just seems... Hacky? Can't really say, that this is a stable, production-ready solution. At least not to my standards as a dev 😉 I feel we can do better here.
What I'm after:
I'm attempting to implement the whole thing as a code stage with no macro-injecting-hope-it-works-hoop-jumping.
The main issue here is this line of the macro code:
My research shows, that it's connected to the Microsoft Office 16.0 Object Library, thus there's no problem to call it via VBA. Soo, I should be able to reference the MSO.dll in the Excel VBO's Initialize page and use it in my code, right? Well, no. The moment I add mso.dll to the references, this happens:23765.png
So far I also had no success in using the Microsoft.InformationProtection.dll to create a valid AssignmentMethod object.
So, my questions are:
1) How do you guys handle the Sensitivity Label in your work envs?
2) Do you have any idea how can I improve my solution to be more bullet-proof (in case of my workaround solution) or work at all? (in case of my "What I'm after" solution)?
3) Does BluePrism, as the provider of the Excel VBO, has any plans to actually address this problem (which is not exactly new, according to my findings)?
SOLUTION:
In case anyone's looking for a solution, here's the code stage (no additional references required):
Dim sensLabel As Object = xlwb.SensitivityLabel
Dim labelInfo As Object = sensLabel.CreateLabelInfo()
If (sensLabel.GetLabel().LabelId() = "") Then
        With labelInfo
            .AssignmentMethod = 1
            .LabelId = "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx"
            .LabelName = "xxxxxx"
            .SiteId = "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx"
        End With
        sensLabel.setLabel(labelInfo, labelInfo)
End If
This, of course, sets a given label just in case of lack of a set label in the workbook. You can modify/delete the If statement to alter this behavior 🙂
Tomasz Sadlon
RPA Dev
Nordea AB
Europe/Warsaw
12 REPLIES 12
BRILLIANT!
It's working, thank you very much! 🙂
Tomasz Sadlon
RPA Dev
Nordea AB
Europe/Warsaw
Thanks @ewilson. Hope the next asset version will support more new actions. Looking forward to use the updated connector.
Athiban Mahamathi - https://www.linkedin.com/in/athiban-mahamathi-544a008b/
Technical Consultant,
SimplifyNext PTE LTD,
Singapore
No worries Tomasz.
Anton Hosang
Director
Omega RPA Ltd
