Exporting and deleting Queue items
AjithranBalasub
Hi everyone,
I like to know how you can export Export Blue Prism Queue Data and Delete completed and business exception items from the work queues for 6 months.
Ajithran Balasubramanian
I think this would depend on how you are adding it.
For a work queue itself, you can go into control room, find your work queue, select all (select row 1, Ctrl + Shift + End), and then right click and "Delete Worked Cases".  Anything that is completed or has an exception will be removed from the work queue and it won't reappear until you add it back.
Hope this helps.
Michael Annis
Rambo27
Level 8
Hello @Ajithran Balasubramanian
Check this -
https://community.blueprism.com/question/extracting-work-queue-data ​
Shikhar Mishra
RPA Lead
Infosys
Shikhar Mishra
RPA Lead
