Filter Excel Column after 3 days from current days
AsitabhaDeb
HI Experts,
I have written below code, for filter the one column with after 3 days from current days.
Dim worksheet as object
Worksheet = GetWorkBook(handle,nothing).ActiveSheet
Dim today As DateTime = DateTime.Today
Dim dueDate As DateTime = today.AddDays(3)
Dim crdDate As Date
crdDate = Date.Parse("09-11-2020")
If (DateTime.Compare(crddate, dueDate.Date) >= 0)
End If
I have applied 3 data item as input variable.
1. Handle= Number
crd date = Text
Due date = Text
But I am getting the below error message. Can you please help me to solve the case. It very urgent.
Internal : Could not execute code stage: Object of type 'System.String' cannot be converted to type 'System.DateTime'.
Asitabha Deb
_Amlansahoo
Level 11
I guess your code is returning dateTime type and you are trying to store it in string. So change the the type from string to DateTime type. Or vice versa
Amlan Sahoo
RPA Consultant
Equinix
Amlan Sahoo
