Functionality of Business Objects
DamianMastalerz
Hello, I have a question regarding the functionality of €˜Business Objects€™ in general. Assumption: Just say we have 10 robots (runtimes) working on a queue and on a single process. Hence 10 robots will do each step identically for the queued items. So far so good. Now I have heard from someone that €˜Business Objects€™ will be locked while they are used. Therefore, in my example 10 robots will wait of each other to use same €˜Business Objects€™. Are they any limitations known that €˜Business Objects€™ can only be used sequentially? For my understanding, it would be against the functionality of modularity. So I would build a module (Business Object) to gain all the benefits like changing logic or something else on one place. But in return if I use this €˜Business Object€™ in many processes which should run simultaneously it would be a constraint. According of what I heard the processes would not be much faster since they have to wait while working with same €˜Business Objects€™. It would be very great if you have a source. Unfortunately, I found nothing about the functionality of €˜Business Objects€™ in deep. Many thanks in advanced.
Business Objects are not locked when in runtime use, they can be used concurrently by multiple robot sessions.  Objects are only locked when being edited.
DamianMastalerz
Thanks a lot.
