HELP Create Collection from Text
SinaHassani
Hi all, I was wondering if anybody could help me sort a Data Item with type Text, into a collection. I have the following information that i need to put into a collection, spaces are intended: Utdata             3092 - Timelønn til utb.    9.75         3095 - Timelønn v/overtid    7.50         3100 - Overtid 50%    5.00         3101 - Overtid 100%    0.00         3200 - Forskjøvet arbeidstid 40%    0.00         3201 - Forskjøvet arbeidstid 50%    0.00         3502 - Utligning sykelønn    2.25                      Ukesavslutning             3096 - Avsatt timebank, arbeidstidsordningen    0.00 - Each new line should be a new line in the collection - Every time there are four spaces after each other, that indicat a new column: Column1 = 3092 - Timelønn til utb. Column2 = 9.75 I suspect that RegEx is needed here, but i honestly do not have experience with it when it comes to Blue Prism. Any help is greatly appreciated! Thank you in advance. Sina
SinaHassani
Anybody?
KonstantinosVog
Hello Sina, You can use the action: Utility-Strings -> 'Split Lines' having as an input your text. This action will split your text to a collection (A) line by line. Then you will loop on the above collection (A) and then you can use the action: Utility-Strings -> 'Split Text' having as an input the row of the collection (A), Split char = ""    "" (4 spaces) and this will give you the collection (B), which will have the format you need :Column1 = 3092 - Timelønn til utb.Column2 = 9.75 Maybe before going to the next loop of collection (A) you will have to store the splitted values of collection (B) to a final collection (C) which will have the overall result of splitted values. Don't know if you can do it faster, the experts can give a better solution or a feedback on mine :) Cheers Konstantinos
