Thanks for your answer.
> If the process provided an output you could check for it.
How exactly can I do it?
Also, on
StackOverflow someone told me that the response to a SOAP request is sent after the process has finished. If this is true, I could simply wait for the arrival of the SOAP response. Is it correct, i. e. is true that the SOAP response is sent to the client (my application that started the BluePrism process by sending a SOAP request) after the process has finished?
Dmitrii Pisarenko
Dmitrii Pisarenko
