How to change BluePrism authentication model
01-08-19 12:27 AM
Hi all,
I'm using BluePrism with BP authentication model (managed by application), and I would like to change it to Windows Authentication.
- Is this change allowed by BP? How should be the process to do that?
- If this change were not possible, should I create another BP instance using windows authentication and republish the process to the new environment?
Thanks and best regards,
Renan
Renan Nascimento
Arquiteto Cloud
EY
America/Sao_Paulo
Renan
Renan Nascimento
Arquiteto Cloud
EY
America/Sao_Paulo
01-08-19 10:27 AM
Authentication mode is specified during repository DB creation and cannot be changed afterwards as far as I know.
The best way I think is to create another instance and migrate the processes. Using release packages this should not be so difficult.
Unfortunately there will be some steps to be done manually still.
Walter Koller
Solution Manager
Europe/Vienna
Walter Koller
Solution Manager
Europe/Vienna
