Hub 4.7 SQL certificates
01-02-23 05:01 PM
so I'm upgrading 4.6 to 4.7 hub and as per 4.7 we need to use ssl certs for the sql connection. while looking at the prerequisites it mentions:
"SQL Server must be configured to use SSL encryption."
This implies that encryption is required.
I need to know if the SQL Server must force encryption (which is a separate SQL Server configuration), or if the driver / interface library will request encryption from the SQL Server.
if its the driver that's requesting the encryption can anyone confirm which driver Hub uses? I believe hub uses DotNet via Microsoft.Data.SqlClient and version 4.1.0.
07-02-23 03:18 PM
Hi Philip,
I understand you have a Support ticket open with this inquiry, but posting the answer here for searchability and visibility.
While Hub 4.7 requires a certificate for SQL Server, it is not a requirement to force encryption.
You can set this in the SQL Server Config Manager like so:
