03-12-21 05:58 AM
03-12-21 08:14 AM
Try Output_Collection = Input_Collection.Copy Dim Newcol As DataColumn = New DataColumn(Column_Name, GetType(String)) Output_Collection.Columns.Add(Newcol) Output_Collection.Columns(Newcol.ColumnName.ToString).SetOrdinal(Column_Index) Success = TrueCatch ex As Exception Message = ex.Message.ToString Success = FalseEnd Try
03-12-21 08:14 AM
03-12-21 01:29 PM
03-12-21 03:04 PM
12-01-22 06:00 AM
12-01-22 02:00 PM
Dim columnCount As Integer = Input_Collection_Two.Columns.CountDim additionalRowCount As Integer = Math.Abs(Input_Collection_One.Rows.Count - Input_Collection_Two.Rows.Count)If Column_Position > columnCount Then Throw New Exception("The column position provided is out of range")End IfIf (additionalRowCount > 0 And Input_Collection_One.Rows.Count > Input_Collection_Two.Rows.Count) Then For i As Integer = 1 To additionalRowCount Dim newRow As DataRow = Input_Collection_Two.NewRow Input_Collection_Two.Rows.Add(newRow) NextEnd IfFor Each dc As DataColumn In Input_Collection_One.Columns() Input_Collection_Two.Columns.Add(dc.ColumnName) Input_Collection_Two.Columns(dc.ColumnName).SetOrdinal(Column_Position) Column_Position = Column_Position+1NextDim rowCounter As Integer = 0For Each dr As DataRow In Input_Collection_One.Rows() For Each dc As DataColumn In Input_Collection_One.Columns() Input_Collection_Two.Rows(rowCounter).Item(dc.ColumnName) = Input_Collection_One.Rows(rowCounter).Item(dc.ColumnName) Next rowCounter += 1NextOutput_Collection = Input_Collection_Two12-01-22 02:10 PM
Dim columnCount As Integer = Input_Collection_Two.Columns.CountDim additionalRowCount As Integer = Math.Abs(Input_Collection_One.Rows.Count - Input_Collection_Two.Rows.Count)If Column_Position > columnCount Then Throw New Exception("The column position provided is out of range")End IfIf (additionalRowCount > 0 And Input_Collection_One.Rows.Count > Input_Collection_Two.Rows.Count) Then For i As Integer = 1 To additionalRowCount Dim newRow As DataRow = Input_Collection_Two.NewRow Input_Collection_Two.Rows.Add(newRow) NextEnd IfInput_Collection_Two.Columns.Add(Column_Name)Input_Collection_Two.Columns(Column_Name).SetOrdinal(Column_Position)Dim rowCounter As Integer = 0For Each dr As DataRow In Input_Collection_One.Rows() Input_Collection_Two.Rows(rowCounter).Item(Column_Name) = Input_Collection_One.Rows(rowCounter).Item(Column_Name) rowCounter += 1NextOutput_Collection = Input_Collection_Two13-01-22 07:13 AM
13-01-22 07:36 AM
31-03-22 04:39 PM
Hi Devneet ,
I tried this code and the problem is in the output .
The flag is shown true but the output collection is empty.
Where can be the problem ?
Thank ,
Erjola
