Hi Else_Lyhne
Use a block with a recover/resume stage around your read image action.
After resuming, If you can activate one of the windows, perhaps you can press the ""close window"" button (spy this) or send keys/send key events to close one of the windows and re-attempt the read image action once more. Use a max re-attempt decision stage before re-attempting the read-image action, so you do not create an infinite loop.
That combined with a wait stage with the ""Check Exists"" condition to check whether the confirm box (Save dialogue box(spy this)) is open at all, should give you an assurance as to whether the window exists at all.
Hope that can help you.
BR,
Mustafa
