Hi Mayank,
I can see many questions. So, I put my feedback to each question.
1. Launching a blank page lot of timesChrome should be opened via scheduler/control room if it was opened in debugging mode. You may refresh the page if there is no elements in the page (Blank Page).
2. Is there any other argument that can make it more stable?I don't know any startup argument may stable the chrome. But you can find many argument from web site e.g.,
https://peter.sh/experiments/chromium-command-line-switches/3. Also if I want to start a fresh session with no cache or history[Ctrl]+[Shift]+[DEL] is the shortcut key in Chrome to clear browsing data. You may clear those data using global send key. Or if Google provides a startup parameter to clear the data, it can be easier.
4. If after launching the website and blank page appears, is there a way to refresh the browser? Yes, you can do that. I attached a sample object. Please have a look.
5. Navigate stage doesn't have option to navigate to a different URL.You are right. Chrome extension doesn't support the action yet. There is alternative. Please check the article below.
https://portal.blueprism.com/customer-support/support-center#/path/Automation-Design/Application-Integration/Browser/1370760452/How-do-I-navigate-to-a-new-URL-on-my-browser.htmCheers,
Nobu
Nobuhiro Tokushige
Product Specialist
Australia/Sydney
