Login agent - Logout issue
27-11-18 05:19 PM
Running logout agent is not successfully logging out the bot in E3. The Logout process runs successfully but it does not log out the bot.
When running 'login agent - login' process, it's giving error message like 'ERROR: Invalid login state: The machine must be logged out to accept a login request'. When I checked on the runtime resource manually from Task manager > User > The user is still active on server.
Looking for the solution. TIA.
27-11-18 08:47 PM
Login Agent is really only intended for systems with one active session. It can work with multiple, but it won't be as reliable. Additionally, if the system was RDP'ed into, Login Agent has been known to fail to operate properly.
When you checked the user list via Task Manager, was this secondary account logged in before or after the error?
