Main Difference Between AA and HTML Mode
Sheen_AnGoh
Hi!   I am wondering for web applications - when do we use AA mode and when do we use HTML mode? What is the best practice for it/ when is one preferred over the other? Thank you!
Assuming you are using IE, use HTML first and consider AA (or UIA if you have 6.2) as an alternative. There is no 'best' way, as all applications are different.
