Method arguments must be enclosed in parentheses.
AsitabhaDeb
I have completed the SAP scripting but when I am trying to run the code in Object level above error is showing. Did I miss anything.
I have attached the screenshots of my code.
Page: Click on Spreadsheet
Stage: Code1
Type: Error
Action: Validate
Description: Compiler error at line 12: Method arguments must be enclosed in parentheses.
Repairable: No
Please help ASAP. I need to submit it to leadership team.
BR/Deb
Asitabha Deb
Best Answers
MadhurChopra
Hey Asitabha,
A quick glance makes me believe the errors you are seeing are a result of the arguments you are passing in rows 12 & 13. I'll suggest placing them in parenthesis and trying again.
I hope this helps.
Regards.
Madhur Chopra
Sr. Product Consultant
Blue Prism - Professional Services
America/Los_Angeles
NicholasZejdlik
Level 9
Try changing line 12 to this:
session.findById("wnd[0]/usr/cntrlRESULT_LIST/shellcont/shell").pressToolbarContextButton("&MB_EXPORT")​
I think it doesn't like that you don't have the parameters enclosed in parenthesis. The old VBA / VBS / VB6 style doesn't require them, but vb.net does.
Nicholas Zejdlik
MadhurChopra
Hey Asitabha,
I hope this helps.
Regards.
Madhur Chopra
America/Los_Angeles
