Multipli error with the same description
SachinBais
hello all, kindly help me with the below Error: Row 1 contains an argument 'internal' that is not defined in the application model. i have a business object  xxxx in which every navigate stage with action Global Send keys gives me above error in error tab, however the stage is working fine. the object is also working fine. please find the error.jpg below for your reference.   Thanks in Advance...
syed.viqar.raza
Hi Sachin, If you are using Blue Prism latest version(6+), then there is option to provide interval (wait) for the response. Please make sure you have given value there.   Thanks and Regard, Syed Raza
SachinBais
Hello Syed, i am using Blueprism version 5 (5.0.30.0)
Hello, have you created a solution in one version of Blue Prism and then tried to run it in an earlier version of the product?  In the navigate stage there is an interval that can be set between each row in v6 but it does not exist in v5, I would expect to see an error like this if you tried to migrate a solution from v6 to v5.
SachinBais
Hello Denis, First the code was built in Version 6 however due to some issues,i migrated it to version 5. thanks for the clarification. Appreciate your help. Thanks
