Number of Licenses required
Daniel_JebarajJ
Hi, Our organization has bought one Production license from Blue Prism. We have requirement of running multiple bots. So how many licenses should be made available? Lets say, I need to run 3 different processes in 3 different machines. Do I have to purchase separate licenses for each of the machines or can I use the same license for all the 3 machines, (If the single license file supports 3 concurrent sessions)? Please advise   Regards, Daniel
A license limits the number of Production processes that can be run at the same time, but it doesn't limit how many processes or machines you have. A 3-limit license could enable 3 processes running on 1 machine or 3 machines each running 1 process. You can install multiple licenses in the same environment, so if you want to build up your capacity from 1, you'll need an additional license.
Venkata_Madhuba
How to determine the no of bots required for each of the environments(Dev, UAT, Prod)?
