OLEDB INSERT Statement
MarinaDutta
Dear All,
I have two excel files which I am opening using OLEDB.
I want to put filter at a column [INPUT]=@ and copy the datas from Column B,C,D,E ,F from the source  excel sheet to another excel sheet B,C,D,E
How to write the Insert statement . Is it something like this below.
"INSERT INTO [Sheet1$] ([A],,[C],[D],[E])VALUES([Output.A]&"",[Output.B]&"",[Output.C],[Output.D],[Output.E])"
where Sheet1 is the name of my destination sheet where data will be pasted.
Source Excel Sheet
25079.pngDestination Sheet
Marina Dutta
Hi Marina,
The CStr keyword is used to cast the data item as String rather than a date while reading. There is a known issue with OLEDB at times regarding date fields, where if you read the dates directly Blue Prism will read the dates as per the regional settings of your machine, so for example in my case , if I have a date say '01-01-2020', then what I got was '31-12-2019 18:30:00' which is incorrect, so what I did is to cast the value as a String so that the the automatic date conversion can't take place. If I want to do some operations on date, I can convert the field into date type in Blue Prism using some other logic which be under my control and not the regional settings.
40 REPLIES 40
Hi Marina,
In order to write the data in the second sheet from your screenshot, you can't directly use that insert query as you data range does not starts from the beginning of the excel sheet which is 'A1'.
From what I can see, the first excel row is going to be blank and the data also needs to be written specifically from B2 cell to E column. Hence your query will get modified like this: "INSERT INTO [Sheet1$B2:E] VALUES('" & [Orders.B] & "','" & [Orders.C] & "','" & [Orders.D] & "','" & [Orders.E] & "')"
Also, keep in mind while using this query you need to loop within the Orders collection and with the loop use this query. The mistake a lot of people do here is that they sometimes even add the Open and Close action within the loop stage. Please avoid that so that you don't face unexpected errors while executing this action.
I have attached a sample workflow for your reference:
Result after execution:
PabloSarabia
Level 11
Exists a quick form to do this.
If you want to copy all form Sheet1 to Sheet2 use the "INSERT INTO SELECT" statement. You can also filter it.
Here is the syntax:
INSERT INTO [Sheet1$] (A, B, C, D, E) SELECT A,B,C,D,E FROM [Output] WHERE INPUT = '@'
Only need to modify the column names
Try it
Bye 🙂
Pablo Sarabia
Architect
Altamira Assets Management
Madrid
634726270
Dear Pable,
Thank You so much for your answer.
Marina Dutta
Dear Devneet,
Thank You so much for your answer. I had one more question. If I want to select only coulmn names from sheet name can I write below.
"SELECT [RequestNo ,[OrderNo, [Parts Name] FROM [Sheet1]" where RequestNo, Order No, Parts Name are column names and Sheet1 is sheet name. Can I use Get Collection to select the columns.
Marina Dutta
Hi Marina,
Glad your issue got resolved. Definitely that will also work for you, the query will be like: "SELECT [RequestNo] ,[OrderNo], [Parts Name] FROM [Sheet1$]"
Just remember the above query always will work whenever you data is starting from the beginning of the sheet, that is "A1" cell. In case your headers, fall somewhere at the middle, the you need to modify the From part of the query.
Let us suppose if the headers go from B2 till E then the query would have been modified as: "SELECT [RequestNo] ,[OrderNo], [Parts Name] FROM [Sheet1$B2:E]"
Similarly, if you want to put a filter as well while selecting the columns you can do by using a WHERE clause, then your query gets modified like this:
"SELECT [RequestNo] ,[OrderNo], [Parts Name] FROM [Sheet1$] WHERE [INPUT] = '@'"
Considering that INPUT is the name of the column where this value '@' resides.
Hope that helps to clear your doubts 🙂
Hi Devneet,
When I tried using that I am getting following error.
Internal : Could not execute code stage because exception thrown by code stage: No value given for one or more required parameters.
Marina Dutta
Hi Marina,
The first row is blank in your sheet and the headers are starting from A2 cell, can you update the Sheet name parameter in your query as: [Sheet1$A2:<Last Column of your Table>]
In the screenshot I can't see which column it is, if it is J then provide [Sheet1$A2:J]
Hi Devneet,
I have selected below three columns only because I wanted only three columns A, B,C . Can I just select only three columns instead of entire columns.
"SELECT [sikeisho担当] ,[依頼NO], [試計書番号] FROM
[Sheet2$A2:C]"
Marina Dutta
Hi Marina,
If they are continuous columns and they fall within the range from column A to column C then yes you can use the query. Let me try to explain you this way, suppose you need column A, B, E and J then in that case your query will be SELECT [A], , [E] and [J] FROM [Sheet1$A:J]. So essentially, your sheet range should comprise the starting column and the ending column range whereas in the SELECT part you only provide the columns that you want to select.
Hope that clears your doubt.
