PDF Problem
NiklasFranke
Hello together,
currently i am more than confused. I managed to open a PDF and to Spy certain elements in that File because i cant just copy and read the clipboard in this case. After i run the process a second time, suddenly the element is not found anymore:
I just have one Process running so i dont think that is the reason
Also suddenly the Applicationmanager cant find the certain Fields in the File, it just can spy the whole file.
After i click manually in certain fields in the file, the Applicationmanager is able again to find the fields. Focus, Attach and Activate doesnt solve the Problem.
I Really dont want to Global Mouseclick and try to find the Fields in the PDF with X Y coordinates, so the spying process is working again. is there a better soloution?
NiklasFranke
I found some kind of soloution. I Tab to the Element and try it 5 times with 5 sec delay. That works but feels very odd
