Perform Vlookp in Blueprism
AsitabhaDeb
I would like to perform VlookUp in Blueprism. Is it possible? if Yes, then how.
BR/Asitabha
Asitabha Deb
NileshJadhavBP
Level 10
Yes its possible,You have to write code to achieve same in excel using Blue prism.
Nilesh
Nilesh Jadhav
Senior RPA Specialist
Nilesh Jadhav.
Consultant
ADP,India
If you're saying you have a value that you know to be in one column of a collection and you want to retrieve a value from another column in the same row, then the easiest way is with Utility - Collection Manipulation::Filter Collection. Assuming that the value you're looking up is unique, it will return a single row. You just store that result into a new collection that will then only have one row and you just need to use a calculation stage after that to get the value from the other column like [collectionname.otherfieldname] and store it wherever, etc.
Dave Morris
Cano Ai
Atlanta, GA
Hey Nilesh,
Can you guide how to use Vlookup between to excel through blueprism.
Sainath.
SAINNATH SURAY
Business process Lead
TATA CONSULTANCY SERVICE
