10-05-23 03:39 PM
Greetings,
I am having a problem spying specific elements in a web Page.
My problem is that when I try to spy the elements I dont find them, I only find the parent element.
Blue prism can't find the rest of the elements.
for example this element is the research input.
here is the Full Xpath
/html/body/pam-root/pam-layout/div/div/pam-r2da/div/r2da-recherche-affaire//app-recherche-avancee-affaire/div[1]/div[2]/form/div/div/input
Is there a way to solve this issue and spy the undetected elements ?
PS: I tried other Spying modes and none is finding the elements.
I have the version 6.10.3 of blue prism
Best regards,
Ghaith
10-05-23 05:16 PM
Hi Ghaith,
Not sure whether you are able to share the URL or when you right click and select view page source contains the html , but your screenshot is indicating the only html tags up to the point having placeholder text - "Rechercher par le nom...."
Did you get chance to try other modes instead of browser mode?
If nothing works then as a last resort I would try region mode.
11-05-23 02:45 PM
Hello @Harish M ,
I tried accessibily mode with --force-renderer-accessibility parameter.
It works but it'll be difficult to work with it. It's less performing than the Browser Mode.
I wish to find another alternative.
After doing my research, I found out that the problem is the shadow DOM.
If anyone worked on this issue I would like to know his solution. Maybe injecting some JS.
Best regards,
