Problems of Async Pattern in BluePrism's Global Code
CHIA-PINGCHIA
Hi everyone, I met a problem when I want to use asynchronous pattern in order to call api base on HTTP protocol. I finish coding the methods and check code and there is no any error. But when I used code stage which call this async method in object's studio and click run, the process can run but it stopped, and my BluePrism application server always crash.
So does anyone have same problem as mine ? If you know what's reason which result in this problem and you know how to resolve problem( I mean you can call aysnc method without crash when process running in Object's Studio ). Please let know, I will really appreciate your any suggestion and answer.
CHIA-PING CHIA
GopalBhaire
Level 10
Not really sure if BP code stages can handle async/await. Try raising a support ticket.
Have you tried using Web API service in system tab?
Gopal Bhaire
Analyst
Accenture
