02-07-20 09:01 AM
Hi,Blue Prism Community
I've been trying to sign in to Blue Prism learning Edition.
But i'm failing.
It seems that I put wrong username or password.
Are the username and password same as them on Blue Prism Digital Exchange?
Kei Terada
But i'm failing.
Kei Terada
04-07-20 09:46 PM
If you install the Learning Edition, during the installation the installer will ask to create a new password for this database, if you don't remember, one option is to remove Blue Prism and Microsoft SQL Server 2017 LocalDB (this is only for the training, so don't worry, nothing else will be affected.) After that re-install and follow and the steps and write somewhere the password you set for the Admin user.
I hope this works for you.
This is the 2 app you need to remove.
Luis Lopez
Blue Prism Ltd
Luis Lopez
Blue Prism Ltd
03-07-20 06:07 AM
The default username should be 'admin' (without the ') and then a password that you should have changed.
https://bpdocs.blueprism.com/bp-6-8/en-us/Guides/trial-learning/tr-installation.htm?tocpath=Installation%7CTrial%20and%20learning%20editions%7C_____1
James Man
Professional Services
Asia/Hong_Kong
James Man
Asia/Hong_Kong
04-07-20 09:46 PM
Luis Lopez
Blue Prism Ltd
Luis Lopez
Blue Prism Ltd
