Schedule works... almost 3 hours later from what it was programmed
17-07-19 05:17 PM
Hello everyone! i have a problem, as the subject said, my schedule used to work properly, but in the recent times keeps working but 3 hours later.
For example:
My process Run at 9:00pm but this run at 11:56pm.
I dont really know what is happening here, what could be the cause of this latency?
I restarted the App Server, Interactive Client and the Runtime Resource but the problem seems to persist. I also know that some versions of Blue Prism has some troubles with the Schedule, (Im using v6.3) and got resolved by updating, but we cant do that because of the politics of the enterprise that we are working in.
Any idea?
Daniel
Daniel Andrés Sanhueza Ibarra
Junior Staff
Deloitte
America/Santiago
For example:
Any idea?
Daniel
Junior Staff
Deloitte
America/Santiago
Daniel Sanhueza
RPA Professional Developer
Deloitte
Deloitte
18-07-19 01:22 PM
Is it exactly the same time delay every time? If so, could it be a time zone issue? Maybe the app server's time zone got changed. Also, verify that the Runtime Resource's time zone matches the app server time zone.
Also, verify that it actually ran 3 hours later. The time shown in Control Room can be deceiving. The time shown as the start time and end time in Control Room is actually the time as reported by the Runtime Resource and not the time that the app server started the process. So, the app server will send instructions to the resource to start up a process. The resource will start running the process and report back a start time which is reflected by the local machine time. So, if you're checking this later in the day, the process may have actually run at the right time but Control Room shows it as incorrect.
Dave Morris
3Ci @ Southern Company
Atlanta, GA
Dave Morris
Atlanta, GA
18-07-19 09:36 PM
Hi David, thanks for respond!
I did what you said so i checked the time zone in every computer but it is the same...
Junior Staff
Deloitte
America/Santiago
Junior Staff
Deloitte
America/Santiago
Daniel Sanhueza
Deloitte
Deloitte
19-07-19 11:03 AM
Here you are: https://portal.blueprism.com/customer-support/support-center#/path/Operational-Support/Performance/Scheduler-Performance/1139601372/Why-are-my-Schedules-being-missed-or-slow-to-start.htm
Hope this helps.
Tetsuji Junicho
Manager of RPA Practice Grp.
Accenture Japan
Asia/Tokyo
Hope this helps.
Tetsuji Junicho
Accenture Japan
Asia/Tokyo
