Hi Rahul,
You have covered all the basic points, few more points that you can add are:
- Security and compliance challenges if any (This could include determining session locks of application along with credential storage determination)
- Check if any differences are there in the applications in DEV and PROD like unknown popups or different links etc.
- Determination of retry points in each screen (from my pervious experience, it's better if you can identify it at this stage only otherwise to avoid unknown surprises in DEV)
- Loading time comparison between each environment (DEV, UAT and PROD). This gives a rough idea about the average time you can consider for timeouts in you process flow.
Intelligent Process Automation Consultant
Blue Prism 7x Certified Professional
Website:
WonderBotz India Pvt. Ltd.
