I want to trigger a process on a Resource Pool instead of triggering a process on a specific resource.
If we have exposed any process as Web Service and if we want to trigger that process using API then we need to provide the machine name as a parameter and the process will be triggered on that particular machine.
Now my requirement is to trigger a process on a resource pool instead of a particular machine.
Can anyone please help or provide any idea on how can I achieve this?
To my knowledge, there's not an out-of-the-box way to trigger a Process exposed as a web service to run on a resource pool, as the machine name parameter is required. However, we have a Knowledge Base article that describes how to load balance calls to a Process exposed as a web service that may work for your requirements instead. This article has a brief explanation and example of how to set up your Runtimes as well as a link to a PDF with more information.
Thank you for good information, @Steve Boggs. It seems that we could use a web server or service bus as an independent proxy provider. Could we possibly use a load balancer (L4 or L7) as an independent proxy provider, either?
