What exactly does Rabbit MQ do in Decipher IDP?
13-05-21 07:44 AM
What exactly does Rabbit MQ do in Decipher IDP? Just wanted to understand what it does and what is its role here in document processing.
Thanks & Regards,
Tejaskumar Darji
Thanks & Regards,
Tejaskumar Darji
13-05-21 08:11 AM
Hi Tejaskumar,
RabbitMQ is a message broking service that facilitates communication between applications. It can be used as a common platform for all your applications to communicate with one another and is also used in our other products, such as Hub and Interact.
In Decipher it facilitates the communication between a Blue Prism digital worker and the Decipher document upload client. It uses queues to separate data (can be process/batch type specific) and credentials to manage access. It's particularly important where Decipher needs to pass information to a digital worker, when they may not be immediately available to receive it.
I hope that helps, but let me know if you have any additional questions.
Ben Lyons
Product Consultant
UK
Ben Lyons
Product Consultant
UK
Ben Lyons
SS&C Blue Prism
UK based
SS&C Blue Prism
UK based
13-05-21 03:45 PM
FWIW - There is a RabbitMQ connector available on the DX if you're interested in using RabbitMQ directly within your Blue Prism processes.
https://digitalexchange.blueprism.com/dx/entry/9648/solution/utility---rabbitmq
13-08-24 10:20 AM
Can azure service bus be used instead of Rabbit MQ
