Work queues not showing up
Choon_BoonLim
I am following the exercise 9.1.2 on work queues in the foundation training course. I did the following: Add a Action Stage select Internal - Work Queues from the list of Business Objects select 'Get Next item' enter "Queue1" as the Queue Name input parameter value. Select the Outputs tab to see the output values and use auto-generate buttons to create the output Data items. Right-click on the 'End Stage' and select Breakpoint from mouse menu. Save process and run page. Close breakpoint message and did not press Reset button. Bring Control Room to the font, and refresh the screen. I did not see any first item in Queue1 which will be marked with a yellow lock icon.   Can anyone let me know what i missed?
Have you run out of items to get? Once you call Get Next Items (I think) 5 times, the items in the queue have been used up and you'll need to add more. You shouldn't attempt the Foundation course without the help of a mentor - I'd suggest you seek advice from the lead Dev in your organisation.
You can go down to Exercise 9.2.1 ""Adding new items"" to fill your queue with new items. You can then execute Exercise 9.1.2. Note that the default queue is named ""Queue 1"" (including space) not ""Queue1"" as in the Tutorial.
