does BluePrism 6.2 support JRE 9? (Appman64 issue)
Hi everyone,   When I run swingset2 at JRE 8 environment and it works. But when I run swingset2 at JRE 9 and Win 10 (64bit) , I even can't launch it. (but i can attach to it)   after the attaching, clicking identify button causes BP crush (and it pops up crushing message about appman64)   Does anyone face the same situation?   (I already have searched any keywords about appman and java 9. and it is no problem about JavaMonkey and JavaFerret in Java 9 environment)
Have you tested your JAB installation using the Java Ferret or Java Monkey JAB test tools provided by Oracle?  That will let you know if it is a JAB issue (in which case you will need to investigate how to get accessibility working with your app) or a Blue Prism issue (in which case you could contact the support team).
