read verification code
EricLi
How to read the verification code from webpage like this image. OCR or read text looks do not work.
Eric Li
Operation Analysis
AIG
Asia/Hong_Kong
esaugos
Hi @EricLi
Saurabh Goswami
RPA Solution Architect
Tech Mahindra
Mukeshh_k
Hi @EricLi : Please see this thread : https://community.blueprism.com/communities/community-home/digestviewer/viewthread?GroupId=145&MessageKey=848de8d5-f21c-4397-886b-318f70a10c56&CommunityKey=3743dbaa-6766-4a4d-b7ed-9a98b6b1dd01&tab=dig...
The Support Centre knowledge base says - Blue Prism as a company respects the right of the designer to implement software which seeks to make this distinction, and does not provide for, or promote, the use of Blue Prism Enterprise software to circumvent such tests, find below link.
https://portal.blueprism.com/customer-support/support-center#/path/Automation-Design/Application-Integration/1142228842/Can-Blue-Prism-Enterprise-work-with-a-web-page-which-uses-CAPTCHA.htm
You should contact the application owner as mentioned by Saurabh, as this could be a potential breach.
Mukesh Kumar
