Blue Prism Product
 View Only
last person joined: 14 hours ago
This community covers the core Blue Prism RPA product.
  • 1.  Conversion of Edge (IE Mode) into Edge Business Objects
    Posted 16 days ago
    We are about to upgrade from 6.4.3 to 7.1.2.  Due to the sunsetting of Internet Explorer , we did the work to create our business objects to run against Edge running in Internet Explorer mode.
    When we move over to the new version we will be importing these business objects over.  once the import is done, would we then need to run the Application Modeller Conversion tool to convert these fully into Edge?
    Stephen Eric Jones
    Blue Prism Developer
    Swinton Insurance
  • 2.  RE: Conversion of Edge (IE Mode) into Edge Business Objects
    Posted 16 days ago
    Hi Stephen,
    Nope, if you intend to keep using Edge IE mode you don't need to make large adjustments your objects. They should run as-is in Edge IE mode with only the slightest of changes. The only adjustment is to have your object start Edge rather than IE, same goes for stopping the browser. And you have to add your URL to the list of sites to run in IE mode within Edge.
    Happy coding!
    Paul
    Sweden
  • 3.  RE: Conversion of Edge (IE Mode) into Edge Business Objects
    Posted 16 days ago
    I will want to run my processes fully in edge mode, I want to stop running in IE mode.
    Stephen Eric Jones
    Swinton Insurance
  • 4.  RE: Conversion of Edge (IE Mode) into Edge Business Objects
    Posted 15 days ago
    Hi Stephen Eric Jones,
    If you do not intend to use the IE Compatibility mode in Edge and fully start working on edge automation then- Yes you would have to re-spy everything and change the attributes. Additionally you can use Application Modeller conversion tool to convert your HTML based objects to Edge(Web based) Objects, but there is no guarantee that it should work perfectly, I would not rely on it.
    More details can be found here : https://github.com/blue-prism/ApplicationModellerConversion
  • 5.  RE: Conversion of Edge (IE Mode) into Edge Business Objects
    Posted 15 days ago
    It's a bit of a pain ,
    ideally I would like to do the import of the process into version 7, run the processes for a couple of weeks etc and then port one process at a time into Edge running fully edge,  but because IE mode is based upon URL's i would have to port all my processes based upon that URL at the same time.
    Maybe i should look into converting into running on the Chrome instead which i can then do process at a time.
    Stephen Eric Jones
    Swinton Insurance
  • 6.  RE: Conversion of Edge (IE Mode) into Edge Business Objects
    Posted 15 days ago
    Stephen Eric Jones it is indeed, also you would want to check if your IE web URLs are being supported on the modern browsers e.g. Edge, Chrome, Firefox etc if some of your URL(Mostly these are legacy web applications) aren't supported on Modern browsers then you would anyway have to enable the IE Compatible mode on the Edge Browser until those legacy web apps are being made to be supported on modern browsers by application teams, in these cases you won't have to do more of changes - Just the path to Edge in Modeller and with IE Compatibility mode on over edge.
    It is worth checking all your URLs on Edge/Chrome manually first and then migrate everything one by one to Edge as per your your approach you said earlier.
  • 7.  RE: Conversion of Edge (IE Mode) into Edge Business Objects
    Posted 14 days ago
    Hi Stephen,
    Indeed, with the checkered history of IE and promises of compatibility from MS over the years, I do not take Edge serious as the next universal browser for the near future. In our case: whatever we decided not to run in Edge IE mode was converted to Chrome. And we will eventually move a way from Edge IE mode in favor of Chrome altogether. And yes, it is quite a bit of work to do so, but what can you do?
    Happy coding!
    Paul
    Sweden
Welcome to the Blue Prism RPA Product Community!
Whether you’re looking to manage a complex infrastructure, maintain security and compliance, bring new products to market faster, or gain operational speed and agility in an uncertain economy, Blue Prism delivers — with the flexibility you need to create the business you want. From deployment on-premise, through a cloud service provider or as SaaS, to a skillful and adaptable digital workforce that continually expands to meet your enterprise needs, you can gain enhanced operational insight and control while your people reclaim the time they need to focus on great work.
Product PageKnowledge BaseBlue Prism Training Offering
Product Research ProgramUpdates, Releases & Announcements
FAQs
Blue Prism is intelligent automation — business-developed, no-code automation that pushes the boundaries of robotic process automation (RPA) to deliver value across any business process in a connected enterprise.
A combination of RPA with expanded cognitive and AI capabilities, Blue Prism is different than other automation technology on the market. With one Blue Prism license, you gain instant access to an already AI equipped digital workforce, along with the tools you need to build and delegate automations. Click here for more information on Blue Prism and Intelligent Automation.
To learn more about how Blue Prism RPA can help your organization and how much it will cost to get started, please Contact our Sales department.
Blue Prism RPA can be downloaded from our customer portal. If you would like to consume or download any material it is necessary to create an account on the Portal. Once you have registered, you can access the download options for Blue Prism here.
Yes! Installed on your own machine and supported by our training materials and product documentation, you can use all the features of the full enterprise product for free with our Blue Prism Trial – giving you the opportunity to learn the basics before moving to a full production implementation. Click here for more information and to download the trial.
Yes! You can access our known issue list for Blue Prism from our Support Portal.
Regardless of your industry, Blue Prism’s Digital Workforce can adhere to strict governance and compliance standards without limiting productivity. Click here for more information on how your industry can benefit from Blue Prism.
