Addition of new column for work queue
SandeepKutwal
Hi All, We would like to add one more column as "Exception Detail" in work queue where we are planning to put some custom detailed exception text in this column , in case something goes wrong . As we know that , Item key , tag , status , priority, attempt , completed , exception date , exception reason etc are default columns but these all columns are currently being used and even we dont want to make any changes to them . I guess , in the BPAWorkQueueItem table , we can add new column for certain workqueue which can be viewed in Control room -> Queue Management if user clicks on that queue . Can anyone suggest how to go for new column addition and suggest if that has support in BluePrism . Thanks , Sandeep Kutwal
You can use the Set Data Work Queue item to overwrite the Work Queue data with a new collection that contains your additional column.
