Application Modeller not able to attach to already opened Inter Explorer
KunalPuranik
I am trying to attach my application modeller to an already opened Internet explorer but its not working. IE version 11 I tried 1. Using just the window title - "Home*": "Error - Failed to launch application - More than one application matched the criteria" . Only one IE instance and tab is open. 2. Using just the process name - "iexplore.exe": "Error - Failed to launch application - Target application could not be identified" 3. Using both : same error The idea is to use a generic object to open IE, and open the webpage and using specific objects to attach and perform functionality.
Try using a navigate stage to attach while using the Child Index input to specify which instance of iexplore.exe to attach to. See https://portal.blueprism.com/documents/browser-automation-guide
MelissaSuarez_G
Also try using the TabProcGrowth configuration (steps included on the Browser Automation Guide)
