Blue Prism won't launch
01-11-21 07:41 AM
If I re-install Blue Prism it works, until the next time I reboot the computer. After that, I'm back to the same issue. It's only on my PC, none of my co-workers are suffering from this issue.
Has anyone else encountered this problem? And if so, how did you solve it...?
Jakob Sørensen
01-11-21 09:28 AM
John Carter
Professional Services
01-11-21 10:15 AM
Jakob Sørensen
01-11-21 01:36 PM
It is normally found in 'C:\Program Files\Blue Prism Limited\Blue Prism Automate\'
If it is not there then you have a problem
Anton Hosang
Smart Automation Services
21-05-24 10:57 AM - edited 21-05-24 10:59 AM
I have the same issue, but even reinstalling it did not do it. There is no entry for it in the event logs.
Did anyone encountered somthing similar?
Barnabas
21-05-24 12:54 PM
1)Please check whether are you using multiple languages in your system. I faced the same issue due to multiple languages earlier.
2)Or else Go to below path and double click Automate.exe file.
If it's opening then well and good if not, either software installation might be corrupted or else whatever launch file we are trying to open that path might be restricted in your PC
"C:\Program Files\Blue Prism Limited\Blue Prism Automate\Automate.exe"
