Chatbot integration with Blue Prism
vinodchinthakin
Level 9
We are trying to create a chatbot using tools which are available online, then wants to integrate with Blue Prism.
Now we have created a flow in Microsoft Power virtual agent , facing issue while integrating with Blue prism using api (which is downloaded from DX), can any one help in fixing it.
Does anyone know any chatbot tool which can be integrated with blue prism.
pls share some articles or video url's for reference.
thanks in advance
vinod chinthakindi
30 REPLIES 30
PritamPoojari
Hi Vinod
I am curious to understand if you are looking to just trigger a job in BluePrism from chatbot?
Instead of trying to directly integrate the two maybe it might be better to keep it simple. e.g. chatbot puts a row in SharePoint list, and BluePrism process which polls the list periodically and triggers the automation.
Pritam Poojari
Solution Architect
Capgemini
