I am Using Itextsharp dll to Extract PDF data, it works fine when running in resource PC. And It also Works fine when running from BP App server Control room. But Issue is when I run the Login Agent and run the process in unattended mode I get Code Stage Compile error when trying to run from App Server of Control Room. Any Help will be greatly appreciated. Thank You!
