Error:Internal: AMI error occured in Wait Start Stage 'Wait for username field' on page 'Login' - External AppMan reader exited before response from query
nikhiln
Hello everyone,
I am trying to launch one of the java application from Edge browser, and it work in the Test/Acceptance Environment, but when I am trying to launch the same application on Production Environment I get this error.
Note: Java Version and Browser Version are same on both the environment , also the BP is attaching to the Java Application.
Please let me know if I am missing something here.
Nikhil
Nikhil
HarpreetKaur
Level 7
Can you try comparing the permissions for the browser in both environments?
And perhaps also check the machine config in terms for bit-ness 32 vs 64. The bit-ness should match between BP and the target app as well.
Harpreet Kaur Product Consultant
Hi Harpreet,
Thank you for your suggestions
The Browser permission is same on both the environments and they both have 64 Bit operating system
Nikhil
