Hi Stephanie,
I would recommend a blended approach of using Java spying where possible and using Surface Automation where there are instances like this.
Java spy mode represents what can be the quickest method and the most robust. However, I've used Surface Automation with Java applications to great effect when navigating trickier elements.
Are you on a more recent version (6.4+0)?
Ben Lyons
Product Consultant
UK
Ben Lyons
SS&C Blue Prism
UK based
