Hi all, can you help with the following issue?
I have a web based app with Java applet. Since client has migrated to Win7, the writing stage that was previously working fine returns this error:
"Internal : Failed to perform step 1 in Write Stage 'Set Details' on page 'Index' - Call to setTextContents failed"
Reading on this page works well, the same element can be spied with java mode, focused and changes with sendkeys, so I'm guessing it's a method issue.
Java version is 1.0.6_39, JAB 2.0.2, JABswitch anabled and windowsaccessbridge-32.dll in place.
BP version: 4.2.35.0 (32 bit while Win7 is 64 bit)
.NET Framework 2.0.50727.5485
