ODBC connection string
how the ODBC connection string should be built in Validation list? I would like to connect to excel. There is an example for SQL database but not for excel.
Thanks.
Zdenek
Hi Zdenek
Im guessing you are referring to within excel​ rather than through blue prism? I've never used this before but there are a couple of connection strings for excel which you can try.
if the File extension is .XLS using below connection string
//In following sample 'szFilePath' is the variable for filePath
Provider=Microsoft.Jet.OLEDB.4.0;Data Source= + szFilePath + ;Extended Properties=\"Excel 8.0;HDR=YES;\"";
// if the File extension is .XLSX using below connection string
szConnectionString = "Provider=Microsoft.ACE.OLEDB.12.0;
"Data Source='" + szFilePath +
"';Extended Properties=\"Excel 12.0;HDR=YES;\"";
Hi, Michael,
well, I was not completely clear probably but the question is related to Decipher and Validation Lists.
Zdenek
