I'm working on a process that's using the Utility Data - OLEDB object. I set up my process based on the Learning Guide Blue Prism - Data OLEDB. I've continued to have the error "Provider=Microsoft.ACE.OLEDB.12.0" provider is not registered on the local machine. Based on the Learning Guide I completed the 2 downloads to fix this issue, and I used the recommendations found on the
www.connectstring.com/excel/. None of these have corrected the error and I'm not sure what else to do. Help Please. Thanks.
