Problem with Hub installation
ChaithanyaKumar
I have successfully installed pre requisites for hub and hub as well. But when I try to open authentication server using the link https://authentication.local  . The web page is not opening with the error the page isn't working. Can anyone help me out with this
Thank you,
Chaithanya Kumar K L
Hi Chaithanya,
Given the complexity of the Hub Installation there could be any number of reasons for the error. The best approach would be to raise a support ticket for this.
Chris McGowan
Senior Technical Consultant
MarkAlexandrovi
Hi Chaithanya,
May be the approach from this article helps you: https://portal.blueprism.com/customer-support/support-center#/path/Installation-Platform/Security/Authentication-Server/1678333542/-INTERACT-HUB-How-do-I-fix-HTTP-Error-502-5-ANCM-Out-Of-Process-Start...
Mark Alexandrovich
RPA Technical Leader
OCS Distribution
Moscow
+79166853117
