Problem with getting data from Chrome using HTML
I am a novice developer. I have encountered the following problem. The application field spied on in IE as an HTML element had the attributes Path -Dynamic and Enabled. I am currently working in Chrome. I spy in Browser Mode. The same application spy field returns the Web Path attributes but does not have the Enabled attribute. I cannot get the value from the given application field. However, empty lines are added to the collection, with no values that appear in the application. Due to the dynamically changing values, it seems to me that I can only download this data in HTML. The Read function has no Data Get current value but Get text, but takes an empty field instead of text. Have any of you encountered a similar problem or know how to solve it?
Ewa Turowicz-Kwiatkowska
15 REPLIES 15
Hi Ewa,
For Browser mode, as far as I know Enabled attribute is not available as it was available with IE mode. But using XPaths, you still can have expressions like:
'//textarea[not(@disabled)]' or '//textarea[@disabled]'
So here instead of textarea, you can supply the tag name which is associated with the element that you are trying to read. If you want to let say read elements which are not disabled then the first example would work and if you want to read elements which are disabled then the second example would work.
Also, on more way to read element values can be to get the source HTML of your web page by using read stage on your entire web page and use 'Get HTML' action:
From here, you can try to parse the HTML using XML business object and get the desired node value as you want. If it is a collection then you need to loop through and add logic to determine the valid values from the parsed HTML string and insert the appropriate values in your collection.
Email: [email protected]
Hi Devneet
Thank you for your interested. I am attaching some details, I do not know if I described the problem correctly before.
I'm using Blue Prism 6.6. and Chrome Version 100.0.4896.88 (Official Version) (32 bit)
setting in application modeler
web path-dynamic-value (HTML adress)
in the i Read block, I don't have the items you indicated, we probably have different versions of Blue Prism
Are XPaths in an Action block? Is this the Utility-XML object? I have not dealt with these elements yet, hence my little knowledge.
Hi Ewa,
The Xpaths are mentioned in the 'Web Path' attribute only. By default what you get there is a generic HTML path like: /HTML/BODY/DIV/UL/LI .... something like this.
So instead of such paths, you can provide either CSS selector expressions or XPath expressions. Again for creating an XPath you need to test it on the Chrome Browser by using the 'Inspect Element' functionality and you can use CTRL+F key to test Xpaths there. Once you have tested it properly you will be able to use the same in Blue Prism.
Hi Devneet
I was unable to get the value from the field using the HTML Path. I tried in different ways with different attributes etc. Apparently the reason is too low version of Blue Prism. I will update Blue Prism to a higher version and then try again.
Thank you for your help 🙂
Have you tried using a newer version of the browser extension with v6.6?
Dave Morris
3Ci at Southern Company
Atlanta, GA
Yes I have.
Chrome is up to date
Version 100.0.4896.127 (Official Build) (32-bit)
Blue Prism Browser Extension, is also installed for version 6.6
Only in IE I can get the value of this field.
The READ block does not contain the data "Get Current Value" but "Get Text". For IE, the "Get current value" option appeared in the READ block, for Chrome I cannot get the current value. I suppose in higher versions of Blue Prism it is possible to download this data, but to check it I have to upgrade.
What I mean is to uninstall the Browser Extension you're using and try a later version of the Blue Prism Browser Extension such as 6.9.
Dave Morris
Atlanta, GA
What kind of element is this? Is it a select box or input text field or what?
Dave Morris
Atlanta, GA
