Remove HTML tags from mail body
I need to be able to remove the HTML tags from the main body of an email. I just need the content as a text.
Anyone knows how to do this?
Thanks!
ewilson
@Evangelina Curró,
You could accomplish something like this using RegEx (Regular Expressions). You could use an expression similar to below to replace HTML tags with an empty string. You'd have to do this via a Code stage.
output = Regex.Replace(input, "<[a-zA-Z/].*?>", String.Empty);
Example set up of a Code stage
Eric
MichealCharron
Level 7
@Evangelina Curró
You could use the "Regex Replace" action in the BP "Utility - Strings" VBO. The pattern I would use for it is "<[^>]*?>".
Micheal Charron
RBC
Toronto, Ontario
Canada
It Works! Thank you so much!! @ewilson @MichealCharron  ​​
