Running Macro in MS Access
ParthibanAyyap2
Hi All, Need a support on this topic, I need to run a VBA Macro created by me via Blue Prism. As we don't any specfic objects for MS access or the actions to perform this. If anyone worked on this topic can share the solution or suggestion to achieve this one.
InJoeKhor
Hi Parthiban,
To connect to MS DB, you can use Blue Prism OLEDB VBO.
A connection to MS Access DB with the OLEDB VBO should be very straight forward.
Here is the link to the OLEDB Utility Blue Prism, this utility provides methods for interacting with Object Linking and Embedding Database
https://digitalexchange.blueprism.com/dx/entry/3439/solution/blue-prism-oledb-utility
In Joe
In Joe Khor
Sr. Product Consultant
In Joe Khor Sr. Product Consultant Blue Prism
