There's no way to turn that off as far as I know. It'll always update the tag with the same text that goes into Exception Reason, even if you manually mark an item as an Exception from the UI. Apparently you can't even untag the Exception Reason from the tags.
Dave Morris
3Ci @ Southern Company
Atlanta, GA
