Blue Prism Product
 View Only
last person joined: 13 hours ago
This community covers the core Blue Prism product.
  • 1.  Oracle Connection
    Posted 3 days ago
    Hi all,
    I want to connect to oracle DB from a client machine, I'm using OLEDB VBO to do this, the error is showing that the"'OraOLEDB.Oracle' provider is not registered on the local machine."
    I'm stuck in downloading the ODAC, can anyone help, please.
    aseel odeh
  • 2.  RE: Oracle Connection
    Posted 3 days ago
    Hi Aseel,
    For interacting with Oracle database, we have a different asset in Digital Exchange I believe: Function for Oracle MDA - Utility - 1.1.0
    Try this business object instead and let us know if it works. You can find the guide required to use this asset properly on the asset page itself.
    Also, I am providing you some reference threads that also you can follow in case you face any issues while using this asset:
    1) Getting Data from Oracle Database
    2) Oracle MDA Utility issue
    WonderBotz India Pvt. Ltd.
  • 3.  RE: Oracle Connection
    Posted 3 days ago
    Thanks for your answer, I tried it but this error has occurred
    aseel odeh
  • 4.  RE: Oracle Connection
    Posted 3 days ago
    Hi Aseel,
    Please check the asset page along with the threads which I mentioned to ensure you have all the pre-requisites in place first as this asset needs additional DLL's to be added in order to work and you might require to download them from Nuget Feed
    This wont be a direct plug and play asset and also I would suggest you to show us the exact errors from your error compiler window to get more details on the same.
  • 5.  RE: Oracle Connection
    Posted 3 days ago
    The error is about the Oracle.ManagedDataAccess.dll  file, am I supposed to locate it in a specific location? it's installed already
    aseel odeh
  • 6.  RE: Oracle Connection
    Posted 3 days ago
    Hi Aseel,
    This DLL must be present in your oracle ODAP installation folder. You can try to copy that and paste it in your Blue Prism installation folder. If you are unable to find the DLL, then you can download the same from the Oracle.ManagedDataAccess Nuget Feed
  • 7.  RE: Oracle Connection
    Posted 2 days ago
    Hello - How is it different from ODBC one in term of capability, speed etc?
    Neeraj Kumar
    Technical Architect
  • 8.  RE: Oracle Connection
    Posted 2 days ago
    Hello - Neverminded i used this and this is awesome.
    1. Much faster then ODBC.
    2. extra action/feature
    3. Require less action stage to get the o/p
    Neeraj Kumar
    Technical Architect
Welcome to the Blue Prism Product Community!
Whether you’re looking to manage a complex infrastructure, maintain security and compliance, bring new products to market faster, or gain operational speed and agility in an uncertain economy, Blue Prism delivers — with the flexibility you need to create the business you want. From deployment on-premise, through a cloud service provider or as SaaS, to a skillful and adaptable digital workforce that continually expands to meet your enterprise needs, you can gain enhanced operational insight and control while your people reclaim the time they need to focus on great work.
Product PageKnowledge BaseBlue Prism Training Offering
FAQs
Blue Prism is intelligent automation — business-developed, no-code automation that pushes the boundaries of robotic process automation (RPA) to deliver value across any business process in a connected enterprise.
A combination of RPA with expanded cognitive and AI capabilities, Blue Prism is different than other automation technology on the market. With one Blue Prism license, you gain instant access to an already AI equipped digital workforce, along with the tools you need to build and delegate automations. Click here for more information on Blue Prism and Intelligent Automation.
To learn more about how Blue Prism can help your organization and how much it will cost to get started, please Contact our Sales department.
Blue Prism can be downloaded from our customer portal. If you would like to consume or download any material it is necessary to create an account on the Portal. Once you have registered, you can access the download options for Blue Prism here.
Yes! Installed on your own machine and supported by our training materials and product documentation, you can use all the features of the full enterprise product for free with our Blue Prism Trial – giving you the opportunity to learn the basics before moving to a full production implementation. Click here for more information and to download the trial.
Yes! You can access our known issue list for Blue Prism from our Support Portal.
Regardless of your industry, Blue Prism’s Digital Workforce can adhere to strict governance and compliance standards without limiting productivity. Click here for more information on how your industry can benefit from Blue Prism.
