Code for replacing character in column values in a collection
KarinaHansen
Hi
Can anyone provide a code (C#), or give advise on, how to replace dot with comma (or other characters) for an entire column in a collection. I need to be able to define which column and I want to avoid looping.
Thank you!
Best Answers
NickLeGuerrier
Hi Karina,
Since you mentioned you want to be able to modify all rows for one specific column, this code should work.
foreach(DataRow row in inputCollection.Rows)
    row[columnName] = row[columnName].ToString().Replace(".",",");
outputCollection = inputCollection;
5 REPLIES 5
NicholasZejdlik
Level 9
There should be an action in the stock Collection Manipulation object for Remove Dots From Headers that should help.
In case you don't have it, this is the VB code:
For Each Column As DataColumn In Input_Collection.Columns
   Column.ColumnName=Microsoft.Visualbasic.Replace(Column.ColumnName,".","")
Next
Output_Collection = Input_Collection​
And the C# version of it:
foreach (DataColumn col in Input_Collection.Columns) {
	col.ColumnName = col.ColumnName.Replace(".", "");
Output_Collection = Input_Collection;
KarinaHansen
Thanks for your reply.
This code seems to be replacing dots in the collection field names. What I meant was the column values - Sorry if this was unclear 🙂
NickLeGuerrier
Hi Karina,
KarinaHansen
Thanks Nick,
I see that you replied in the other thread as well 😄
I get this error when I try to define columnName as input and run it:
Internal : Could not execute code stage because exception thrown by code stage: Unable to cast object of type 'System.Data.DataColumn' to type 'System.Data.DataRow'.
KarinaHansen
It works now - There was a mistake in line 1.
Had it saying:
foreach(DataRow row in inputCollection.Columns)​
instead of:
Thank you very much 🙂 🙂
