Appending to a collection only adds at the end. If I want to add a field to a collection in the middle (or after/before a specific field) I have to split the collection in two at that point, append to the left collection and then merge the two back together. Would be easier if there was a utility that could do this by passing the filed you want to place before, and if blank (or not passed) would add to the beginning. This is helpful when converting a collection to JSON and needing the fields in a certain order to match (so text replacement can be done if needed on the JSON string as compared to an expected value)
