RobertRoginer
Status: New
The "Mark Exception" action automatically creates a tag if the Exception Reason is not empty. The automatically generated tag has the format: "Exception: {Exception Reason}".
The exception reason often contains case-specific data. E.g., "product 523462 could not be found.". Blue Prism then creates a tag from this exception reason, causing our BPATag table to grow indefinitely.
1 Comment
blue_meanie
You could build your Exceptions to not have case-specific data in, but log the case-specific data immediately prior to the Exception occuring.
This way your BPATag table would not have a load of unique values, business users would see the high-level reason it was failing (and you could use this for high level metrics) and the developers could still check the logs for the specific reason for failure.
